case porting
case porting
when flowing cases is it neccesery to use devcon(epoxy), thought id ask first to make sure, also any pics would be helpful cheers matt.
Ok a piccy of how I flow the cases
Front oil pickup is filled then the oil hole is re-drilled - make sure it is clear and the correct size otherwise your mains will go west
Most of the work is on the reed side - smoothed and filled. Piccy not pretty but it works and is smoother than it looks
It can all be done with a Dremel - some JB weld make sure cases are free of grease and score the surface to give it something to bond to - and patience.
- mr_bungholeo
any chance of a head down shot n through the reed hole?....also why fill the oil feed hole n drill it back out again?...smaller/larger?different place......any help appreciated....
danny harris.....R.I.P
gone but totally forgotten...
- mr_bungholeo
cases nearly done now, just finishing off to, blending both surfaces together etc. managed to get some jb weld, only just though as the pack i got would be one of the last availible as it will be replaced by something else, bloke at counter reckons so any way? very messy stuff also time consuming like you said but pleased with result, just got to see how it holds together, though by the look of it there wont be any problems in strength! thank's for advice/info btw, how did mallory go? cheers matt p.s what size drill bit did you use for the oilway to the main's:?:
