This might take a while!!!
Re: This might take a while!!!
Unless you are a musican, drummmer and your ears are already stuffed you should be using earmuffs,
Even more importantly the eyes! its very hard for a nurse to find splinters of aluminium because they fail the rust solution tests
Good work
Good work
Don't worry, had my safety goggles well and truly on.. My close up eyesight is so bad I practically have to have my nose against the cutter so I've always got them on.. I put the earplugs in after about 5 minutes, Dremmel is a noisy little bugger effective though! I had the motor hung up on a shelf next to my right ear so I'll just use the left for the rest of the weekKR-1R wrote:Unless you are a musican, drummmer and your ears are already stuffed you should be using earmuffs,
Good work
Plenty of time now with all the bits gone away for some work on the cases, a lot more material to remove than on the barrels, poor little Dremel getting some grief! Just the first side has taken about half an hour so far and more dressing to do but hopefully the pics show it. Thanks for the pics on the racing section Luders, gave me plenty of guide to go on, I've probably misssed the same flow you create but it should be an improvement on standard anyway. Decided not to go through with filling on this engine but will give it a go on my spare next year.
Sections to be removed roughly decided
First side mostly done
That will be a good improvement, good job.
Remember to put a radius on this area too
Hadn't spotted that! will do..Luders wrote:That will be a good improvement, good job.
You'll genuinely notice the difference in your motor just from what you've done there.
"You'll genuinely notice the difference in your motor just from what you've done there."
Looking forward to finding out, shame it's going to be a few more months yet! Finally got the most of the work done, just the edges to radius and some cleaning up. All I need for the motor is the crank and barrels back and I can finally get it back in one piece.
You can take more from the top part marked and round off the sharp edges of the other circled area.
Did you get the frame painted?
Yep, frame, swingarm and footrest hangers back into silver (had already been sprayed before and paint wasn't in great shape). A few bits I forgot to get done, sidestand hanger and some rear brake bits, have to decide wether to send them or just try match those myself wih some Halfords rattle cans.
Bodywork, tank and wheels still in progress.
I'm looking at doing a restore and contemplating paint or powder coat
Hi Ben,
There are only two choices...... Paint or Solvol (and you know which one I prefer)
Bernie's right, but as I've got the patience and attention span of a wasp that cut it down to 1 choice really!
Pleased with it, it kept the detail really well and the sprayer is doing a really good job, bit of a drive to Ilkeston but worth it to leave it all to someone I can trust with it. I've seen some pics of plastic coated and read that it can end up a bit thick and plasticky looking, and loose detail/frame number.
