Hi, a couple of the threaded nuts that are fixed into the frame have gone missing. I have brought some more and i am wondering what to use to bond them back in?. They look like they were a press fit. how do you guy do it., I thought something like sikaflex might do it.
Andrew
How do you re fit threaded frame collars
Re: How do you re fit threaded frame collars
you need a special insert tool, they are a bit like pop riveters
old photo with a old phone but ,in confined spaces or if you dont have the tools a simple nut with clearance you can get a spanner on ,a few greased washers and a bolt with the same thread ,just pull it up till its tight
[/URL]
[/URL]-
Mbuk
Thanks for the info.
Andrew
Andrew
If they are alloy it's very easy to strip the thread
