Page 6 of 10
Posted: Wed Jan 09, 2013 9:13 pm
by will77
Look whats come back, i am excited even more now, picking engine up saturday from martin so all coming together now, apart from the rear brake bar that i damaged today....oops
oh well the Rad looks Good
onwards and upwards
Posted: Wed Jan 09, 2013 9:59 pm
Hi Will,
Nice rebuild on the radiator
Posted: Tue Jan 15, 2013 10:27 pm
by will77
Posted: Sat Jan 19, 2013 6:38 pm
by will77
Posted: Sat Jan 19, 2013 7:02 pm
by martin
getting there will. side fairing brackets need loosening and then moved so
they are pointing downwards
Posted: Sat Jan 19, 2013 7:08 pm
by will77
martin wrote:getting there will. side fairing brackets need loosening and then moved so
thanks martin, 1st Job in morning...
if you spot anything else, Please let me know, i wont be offended as you know its the 1st bike ive built
p.s - thanks for tip about bottom engine Bolt and spacer
Posted: Sat Jan 19, 2013 8:07 pm
looking good
apart from your KIPS links : they are setup wrong, check the manual
Posted: Sat Jan 19, 2013 11:35 pm
by martin
I set them up jan, I would say they are correct, inwhat way are they wrong.
in the photo they are in the open position
Posted: Sat Jan 19, 2013 11:41 pm
by tescr500
they will be correct when cables go on and the middle is at an angle as oppose to straight acroosss
Posted: Sat Jan 19, 2013 11:50 pm
by will77
Thanks guys, I've been looking at all sorts all night to clarify, knew martin would have done right.
Posted: Sat Jan 19, 2013 11:58 pm
by tescr500
make sure you remove a linkage bolt on left barrel just incase very tight, don't want to be snapping valves
Posted: Sun Jan 20, 2013 12:48 am
by will77
tescr500 wrote:make sure you remove a linkage bolt on left barrel just incase very tight, don't want to be snapping valves
Left being left as sat on bike?
Posted: Sun Jan 20, 2013 8:03 am
by tescr500
Posted: Sun Jan 20, 2013 11:14 am
tescr500 wrote:they will be correct when cables go on and the middle is at an angle as oppose to straight acroosss
no they won't
if you look at this picture :
you can see that the hole for the cable on the left link is on the wrong side (left) of the valve. you can not even attach the cable like this, let alone they will not open/close correctly.
Posted: Sun Jan 20, 2013 11:29 am
by will77
i am now cold as i had to go back in the snow to push the kips valve with my little pinky to the left to show that they look right
hope this helps clear it up
