My project so far
Re: My project so far
Post by maccas »
Awesome stuff, really cool to see something so different being done to the KR.
I'm guessing you'll be having custom pipes made?
Where are you aiming for peak power rpm wise. The 5ke peaks about 12250rpm, I'm guessing with the modified KR crank you won't be aiming as high as that?
Dan
satarn
Post by satarn »
Power wise we will have to see on the dyno , I will only be running on Shell V Power pump fuel , no additives . The long stroke engine Graham has tuned to have max power at about 11250 rpm and the standard stroke engine at about 12500 rpm . Tony Green will be making the expansion pipes for both engines .
satarn
Post by satarn »
Vforce reed valves now ready to fit .
what carbs are you using and when will your pipes be ready?
c&c
Post by c&c »
Good Jesus ,jaw dropping stuff,,,
satarn
Post by satarn »
As you can see progress is slow but exhausts are now made by Tony Green and engine is fitted in frame.
satarn
Post by satarn »
satarn
Post by satarn »
satarn
Post by satarn »
Looks tastey well done
Post by maccas »
Very impressed! Those pipes look amazingly well made!
Dan
still my favourite KR ever, and it's lead is only increasing =D>
satarn
Post by satarn »
Power valve motor fitted , cabled and wired.
satarn
Post by satarn »
satarn
Post by satarn »
Airbox lid modified.
