Just when I thought everything was done.....
KR1Paul mentioned at Japfest that it was a struggle to fit the bellypan on with Lomas pipes fitted, I had a problem before the show and had put it down to fitting NOS brackets. But when I looked closer the pipes were hard up against the bellypan and would have wrecked it and the paintwork if I had ran the bike.
Lucky I had a spare bellypan to play with, I looked to see where it was fouling the pipes and cut away the offending plastic, then tried it to see if it fitted better......after a few attempts I managed to get about 10mm clearance.
The practice one.....
The finished one...
I left 20mm of the central support in place when I cut out the centre, this keeps the sides rigid and they don't need any more support.
Just need to take the bellypan back to Steve the painter for him to airbrush the edges where I cut, then I need to fit some heat reflecting sheet on the inner surfaces. I think I will try a sheet of the Zircaflex, if is good enough for McLaren and Lamborghini it is good enough for me
I now have a spare modified bellypan to suit Lomas pipes
Thanks for mentioning it Paul, otherwise I would not have noticed
