2x engine build
Re: 2x engine build
i can make it into a rolling chassis
look at the front mount and how im going to do it
then send it for exhausts making
Re: 2x engine build
Hi Gary,
Looking good
But even by my standards, I think you are a little bit early with the Mr Sheen
Keep the photos coming [-o<
Looking good
Re: 2x engine build
i need some help with some bearings
i cant find any headstock bearings [taper]
for zxr400 l forks in rs frame
top bearing
width 15mm
bore dia 35mm
outside dia 47mm
bottom bearing
width 16.5mm
bore diameter 35mm
outer diameter 52mm
if anyone can find me some that would be great please ?
i try'd for 4 hours yesterday ,i dont think im going to be able to use zxr front end
rs250 std is 25
top bearing
width 15mm
bore dia 35mm
outside dia 47mm
bottom bearing
width 16.5mm
bore diameter 35mm
outer diameter 52mm
rs250 std is 25
Re: 2x engine build
I think your bike deserves much better suspension than ZXR400's. something from mid 2000 onwards.
Re: 2x engine build
thats what i will be after ,something like those
a mate has a complete spotless front end off a fire blade 2000 model
usd forks they look like new but maybe a bit old ,i can have a look for nothing
it will be on its wheel tomorrow i hope
today i got deliverd
front rs250 wheel
radiator
brembo rear caliper and carrier
rear subframe
front subframe
head bearings
and a couple of other bits
a mate is picking up the engine mounts to bore the holes to 12mm on something better than a hand drill
saturday and will bring them back sunday
and i can get the engine lined up and trace round where i want the brackets welding to
then strip it again and get it to a welder
front rs250 wheel
radiator
rear subframe
front subframe
head bearings
Re: 2x engine build
had the engine sat in the frame today
marked up where the brackets need to be welded to
take it apart and get the frame off for welding
Re: 2x engine build
Ah nice work Gary
Re: 2x engine build
man that engine is rather huge
carbs (and airbox) still need to go on, already thought about a radiator ?
- Binetta Steve
Re: 2x engine build
Nice cutaway photo hereJanBros wrote:man that engine is rather huge
http://www.motorcyclespecs.co.za/model/ ... %20due.htm
Re: 2x engine build
Great project, Love seeing it progressing
Re: 2x engine build
ive been told the radiator is big enough but i know where there is an uprated thicker radJanBros wrote:man that engine is rather huge
of an r6 but made professionally to fit rs250
just waiting on a price for it
- tescr500
Re: 2x engine build
HI some great photo's there looking really good. Hey Luders some great engine porn there don't you think =D>
