Page 28 of 44
Posted: Tue Apr 08, 2014 1:09 pm
I'm quite a way off yet, I need to finished the airbox, I am waiting for a radiator, I need to make a wiring harness and order the CDI. The barrels need to be finished and exhausts made. It will run one of the Janbros heads and I'm waiting for a few other bits and pieces to be made or finished off.
I'm getting closer each week, but aiming for June/July to get it running and down to the dyno for setup.
We (Lozza and I) have a target bhp and peak rpm for this engine, so I'm hoping for some impressive figures once it's all ran in and setup.
I'm fitted a Koso dual EGT sensor, as well as this little volt meter I picked up for a couple of quid.
Posted: Tue Apr 08, 2014 2:49 pm
any figures about your engine you can share with us , like timings, compression, squish, ... ?
while mine is still open thinking abou any cganges to be made
Posted: Wed Apr 09, 2014 3:36 pm
It's losely based on some ideas taken from the aprilia, is all I'm prepared to say. Frits Overmars is a good source of information if anyone is interested.
Posted: Fri Apr 18, 2014 6:13 pm
Been working on the front sub frame today. There's a mounting plate for the tacho and mounting trays for the CDI and battery.
Posted: Tue Apr 22, 2014 4:42 pm
Been working on getting the clutch inner all plugged up. Water pump, oil pump and kick starter holes all blanked off and fitted.
Posted: Tue Apr 22, 2014 6:06 pm
by jarno
your not going to use the waterpump Ben
something electric?
Posted: Tue Apr 22, 2014 6:30 pm
Exactly Jarno, going for a Davies Craig EWP.
Posted: Tue Apr 22, 2014 8:42 pm
by KR-1R
you need to get the LC boyz to whip you up a perspex pump cover
you could then make use of the drain bolt to mount a nice blue LED
Posted: Tue Apr 22, 2014 9:03 pm
That's not my style Danny, I go for functionality over faf
Posted: Thu Apr 24, 2014 7:58 pm
by scooble
is the pump going to be a constant speed, or will it be variable, if so, how will this be controlled?
Posted: Thu Apr 24, 2014 9:23 pm
I'll explain to cooling later as it all turns up, but I'm not fitting a controller, it's just going to be constant speed, shifting about 15 lpm.
The radiator should be turning up any day now, so if it's not with me early next week, I'll be chasing the manufacturer.
Posted: Fri Apr 25, 2014 11:28 am
Posted: Fri Apr 25, 2014 6:16 pm
Well done Ben, 10/10 for attention to detail =D>
Posted: Fri Apr 25, 2014 6:51 pm
by KFOR
Some great progress Ben ! =D>
Posted: Sat Apr 26, 2014 5:40 pm
I'm getting there slowly
Thought I would try the clothes on today
I've actually been designing the wiring loom today, nothing productive in the garage today.
