Yep, was never rebored because it never needed it, ran smooth as a nut...when it was running. Looks better than I thought it would under the heads. They've been off before, but only to clean the carbon off the pistons (many years ago). Was finally laid up due to the crankshaft oil seals failing; last ran in 1993.
The coils certainly didn't look like that the last time I had that cover off; it was all shiny!!!
Gary,
Were it goes down through the opening in the side engine casing next to the three oil lines, which then go to the oil pump it was rubbing on the top of the casing.
Brilliant!
I like it,not sure if the generator is worth saving though.....
Pipes (off the bike) look like Denco or maybe early Allspeeds as they came without the headers on some models.
Got your work cut out,but its all part of the fun.
I picked up an original seat of ebay which was a find as it has all the four metal side trims, have cleaned the seat and left the trims in primer as they will be sprayed with the bodywork.
Tidy!
It never ceases to amaze me,how good things can be when done right.
I am really looking forward to seeing this one finished.
Well done that man =D> .
