KXR-1SS
KwakOn
Post by KwakOn »
Looking good (as usual) 8)
got one of those wee engines a while ago :P :D
cant wait to start fitting it - but I will have to as I need to finish the rebuild that I have started (race bike with lights :twisted: ).
It will be a proper job yours, I will try and build mine so it can swap with the standard engine which might not work :?
.. Image ..
FLaT-SiX
Post by FLaT-SiX »
Jan.......it's impressive, fantastic project =D>
i'm looking forward to see and hear you driving on the Belguim roads with the KR500. I will admire that beautiful 2-stroke monster :!:
FLaT-SiX wrote:Jan.......it's impressive, fantastic project =D>
you'll have to come to the tracks to hear it :)
exhaust is adapted. had to cut it 7 times to twist it in the right direction (and cutting made it also far more easier to get rid off 2 huge dents).
compared to KR1's exhausts, that is one huge m****rf*cker :shock:
KwakOn
Post by KwakOn »
8) 8)
good work, great pics.
=D> =D>
.. Image ..
:shock: 8) Big hat tip to you Jan,Class =D>
TwoStroke Institute
Post by TwoStroke Institute »
WTF did you weld that pipe with???? It's a crime [-X
crochet & croquet
right about now,
"a face only a mother could love" springs to mind...
TwoStroke Institute wrote:Here you go Sheik some pipe developement for you :wink:
...a bit less time in Surf class and a bit more time in Shop class, LoZza?
TwoStroke Institute wrote:WTF did you weld that pipe with???? It's a crime [-X
My guess is.....a welder!
Is the saying something like"Don't mistake the container for the content"?
Or is everything to be judged on looks?
NOS EXUP
Post by NOS EXUP »
That will hold - plenty of penetration
whats the problem
Looking Good.....
well, wish I had a TIG, but if I ever buy one, it will be one that also can weld Alumnium, and they are way to expensive for me at the moment.
and you're right, for the moment it looks like crap but it does the job :wink:
finishing it is for when I now everything is working ok and the effort isn't wasted .
put on a radiator today : from a TDM850.
might be a good alternative for a KR1 to, allthough it might be a bit too wide.
pipes are where they should be, and it's twice as thick as a standard one.
measures :
TDM : 39 x 19.5 x 3.5
KR1 : 35 x 23.5 x 1.5
took me about a month, just to get the kick on :?
kick shaft was inside the frame, and just mm's under the frame. made a support that bolts into the frame, with a teflon "bush-bearring" inside, trapped shaft to get the forces from one side to the other, and with a sleeve over it so they stay where they have to be.
Vollegaaz
lurker
Post by Vollegaaz »
Nice Job Bros :wink:
silencers are finished. all homemade.
volume of both is a bit bigger than the original Kwak one, in an attempt to get it as silent as possible. Didn't go for one big one as I didn't have a aluminium tube big enough.
still need to make a bracket to support them.
KwakOn
Post by KwakOn »
=D> =D>
like the look.
surely the Y section would 'silence' quite a bit of the sting as well. Its the first split in a 2T exhuast that I have seen. Hope it works for you.
.. Image ..
Post by scooble »
I've seen some Aprilia RS50's use this system - purely for pose value (for the Aprilia that is).
Also found using that ceramic exhaust bandage makes a big difference to the volume too. I have nikons and they're quieter than some standard KR's
