Page 3 of 10
Posted: Sun Feb 01, 2015 1:59 pm
by headcoats
Looks the same picture but it's not
Thruxton Longer shocks,rebuilt forks with Thruxton internals,Thruxton 17 inch alloy front wheel,chunky fuel cap,fork gaitors and LSL "Clubman" style handlebars
Posted: Sun Feb 08, 2015 1:36 pm
by headcoats
Put in a Angel Eye headlamp like we fit in our LC's,still looks retro me thinks
Posted: Sun Feb 08, 2015 1:39 pm
by headcoats
With the Thruxton down pipes fitted it looks like the cheapo universal silencers have a better chance of lining up
Need a link pipe which will need to be angled and go from 1 1/2 diam to 2 inch
Posted: Mon Feb 09, 2015 12:02 am
Hi Martin,
Front mudguard and sprocket cover?
Posted: Mon Feb 09, 2015 9:48 am
by headcoats
Mornin Bernie
I will re fit the original sprocket cover but the front mudguard has been a bit of a pain
As I have fitted the Thruxton front wheel which is an inch smaller at 18 Inches the lugs on the forks to mount the fork brace/mudguard are now too high.
I hope to mount the mudguard "under" the fork brace to bring the gap down but the second hand mudguard I bought doesn't fit even though it's a Triumph Bonneville part
There is a model called the Bonneville SE which has cast wheels and the forks are set wider so the mounting holes are about 20mm out which I wasn't aware of
Posted: Mon Feb 09, 2015 12:39 pm
Looks lovely that Martin
Posted: Mon Feb 09, 2015 1:39 pm
by headcoats
Anyone know how I can measure up for the link pipe from the headers to the silencers [-o<
Posted: Thu Feb 12, 2015 9:28 pm
by garye345
Would a tailers cloth tape with some wire do it? Or easier still, bend some wire to where you want the exhaust pipe to go, cut it to length, then measure that bad boy.
Or have I missed the canoo proper
Looks tidy all the same heady.
Posted: Tue Feb 17, 2015 12:21 pm
by headcoats
Measuring angles is beyond me Gazza,i get a different measurement everytime
Been putting it off but now delving into the carbs !!
They are CVK 36 Keihin carbs with heaters ,TPS and stuff so pretty different to the PWK 28 carbs I have been messing with the last several years
The idle mixture screw has perished 0 rings and one washer missing so looked on the Triumph microfiches and you have to buy the complete screw which is £23 per screw
Just need to find some Viton 0 rings and a tiny washer then [-o<
Really clean inside but the slides have a little scoring on the engine facing side but look new airbox facing side
Just going to buff them up as they are £53 a side
Posted: Sun Feb 22, 2015 2:36 pm
by headcoats
Carbs are on
On advice got these settings so will have to suck it and see once it is running
130 main jet
42 piot jet
shim under needle (no clip positions)
3 turns out of idle mixture screw
Posted: Sun Feb 22, 2015 8:21 pm
by Binetta Steve
Really neat that enjoy as the weather improves. I was in my local Triumph dealership yesterday and nothing, nothing looked as good as yours. Yup they ave Thruxtons Tiger adventurers but they all lack that personal " this is what I like" input.
Posted: Sun Feb 22, 2015 9:14 pm
by headcoats
Thanks Stevo
Been a pain trying to get a front mudguard and I have an allergy to aftermarket fibre glass ones LOL
Just missed out on one as I was trying to do a deal and someone came in at the asking price which is fair enough
Wanted to get a black front muddy but maybe a silver one will be o.k. as there is silver on the tank
Posted: Sun Feb 22, 2015 9:44 pm
by shandyboy
That looks very nice
Posted: Fri Feb 27, 2015 5:01 pm
by headcoats
Must have been ignoring the rear end
So need to sort out
Rear disc worn out
Brake pistons corroded
Brake hose corroded fittings
So I need to get a good second hand disc, stainless brake pistons,new seals and brake hose with stainless fittings
Posted: Fri Mar 06, 2015 1:43 am
by headcoats
Back to the front
Looking to get all the electrical connectors back in the headlamp shell
Real poor design it makes the LC seem light years a head in comparison
Everything has to cram through one hole which is awkward enough but getting the headlamp lens in with all those huge block connectors is going to be a fight
