Re: My winter project.(Now finished)
Posted: Mon Sep 21, 2009 8:59 pm
375 wrote:Hope to have it up and running for the summer, just got to get the tank painted then on to the engine which is half done.
Next project will be to tidy up my 1s.
Very nice mate i did the same conversion some years back and found i had to remove the swing arm pivot points on the frame and lower them by 25mm or the chain cuts through swing arm because the swinger is longer than the lc one,,if you look at your pic you can see the angle of the rgv swinger is to steep hence if you remove and reweld the frame mounts 25mm lower the chain runs spot .
