Page 2 of 7
Posted: Thu Sep 27, 2007 2:21 pm
by SHimmer45
ok cool thanks Elf =D>
Posted: Mon Oct 01, 2007 10:51 pm
by SHimmer45
some more news....
btw Ali if i edit the original post does it flag up as a new post rather than me tagging a new reply on the end of the thread??
Posted: Sun Dec 30, 2007 10:45 pm
by SHimmer45
right bike is COMPLETELY in bits.
frame wheels and swingarm are ready to be sent for powder coating.
going to have to replace all the bearing in the bike, and i forgot how much some of them are
Posted: Sun Dec 30, 2007 11:20 pm
by Red Devil 777
Have you priced up all genuine kwak bearings? Just you can definately get some cheaper from a bearings factor.
Posted: Sun Dec 30, 2007 11:28 pm
by SHimmer45
wheels are some of the bearing i can prolly get from a bearing factor but im sure a couple of the suspension/swingarm linkages are kwak only jobbies
Posted: Sun Dec 30, 2007 11:39 pm
by Red Devil 777
You can definately get quite a few of the linkage bearings from a bearings place, I think the needle rollers in the botom linkage ones and some of them in the linkage unit are easy enough to get, seem to remember about 4/5 quidish (but may be wrong
Posted: Sun Dec 30, 2007 11:41 pm
by ScottaKR
Don't go just by part numbers. Take samples down to your local bearing supplier and he can measure them up and most likely find a suitable replacement.
Cheers mate, Scott.
Posted: Mon Dec 31, 2007 9:59 pm
by Bikemike
I found brt bearings in Southampton ( on the industrial estate opp. west quay) most helpful, I just took in the old bearing and they sorted me out.
Mike
Posted: Fri Jan 04, 2008 1:08 pm
by SHimmer45
updated 1st post if ppl are following this
also if any 1 interested i can post up the dimensions of the ally caps a mate made for me to cover the headstock and bearing area's if that is any use for the KR Kive etc
Posted: Fri Jan 04, 2008 2:01 pm
by alimorg
SHimmer45 wrote:btw Ali if i edit the original post does it flag up as a new post rather than me tagging a new reply on the end of the thread??
I think it works when you edit the original post as well but I will check to make sure.
AL
Posted: Fri Jan 04, 2008 8:29 pm
by mr_bungholeo
yup i also use brt bearings but in ilford...every bearing ive taken to them they have had in stock...great place...
Posted: Tue Jan 29, 2008 5:03 pm
by SHimmer45
Update to original thread
Posted: Tue Jan 29, 2008 9:14 pm
by Red Devil 777
mmmmmmmmmmm, black
Posted: Wed Jan 30, 2008 12:09 am
by SHimmer45
hmmmm indeed..
cooking on gas now
Posted: Sat Feb 09, 2008 6:15 pm
by SHimmer45
Got some bearing appear today
BRT werent able to match the Swingarm bearings, so those are OEM along with sleeves as the ones in the bike are duff (£80.00 all in for those
Other bearing i have ordered from BRT and they were helpful so recommended,
so ALL of the bearing for my bike should come in at under £150 which i think is good, should mean it will as tight as a nun's whatist.
next on the list is get my mate to assist pressing them in (this project stuff is a big learning curve
erm get a set of boots for it and polish the fork legs.
so depending on time and cash flow possibly have a rolling chassis by next month
