The Hybrid
- corky
i hav a collection of zxr400/250 usd bits, inc full set of forks yokes etc sat in my garage think 400 forks hav a little damage, but i hav the 250 yokes which r like rockin horse pooh!!
the 250 forks outer tubes are good but a lot longer than the 400...was going to mix/match but wont fit !!
got a reply back from maxton about my forks...
"The forks look externally very similar to the 750, but internally there are quite a lot of difference - it is a much cheaper fork inside. One of the big problems with the ZXR400 forks is that the oil is metered at the top of the fork. We modify the forks so that the oil is metered at the bottom of the fork, this gives the fork a much smoother action. We also increase the rebound damping and reduce the compression damping, this helps the bike turn into corners and hold a better line exiting corners. We also fit harder springs to suit your rider weight to stop the forks diving under braking. "
The cost of the conversion is £250 plus VAT and carriage. Seals would be £20 plus Vat and bushes if needed would be £20 plus VAT.
kr1s project wanted
aprillia rs125 track bike
03 r6 race/trackbike
dr500 flat tracker project
Matt
I would def go with the maxton conversion that Corky just mentioned but before you do it, just get the bike built with some ZXR forks and a decent rear shock and give it a good thrash
. The fork rebuild can be do at a later date as cash allows.
- corky
35mm carbs
going to see if i can fit remote idle adjusters and choke pullers..
just need vforce or boysen reeds, enlarged airbox ( 1litre per 15hp!!) and throttle cables....
getting there...
getting there...
kr1s project wanted
- corky
the standard choke cable will fit without any problems. Its the throttle cable that needs modifrying to give a longer pull to open the cables fully.
Allens Preformance for the slidescorky wrote:is a #5 but the other one has nothing on ithow can i tell?
and where will i get the #6 slide?
the slide should have a number on top, note the shape/angle of the cut out on the slide. im not sure but it appears you have a 5 and a 6? allens are the main agents as elf said, how much are slides anyway?
- corky
Corky
Those crash bungs look ace. When will you have the beast finished? I'm looking forward to seeing the finished bike.
- corky
if i can get the time off, got oulton on the 8th, but defo booked for anglesey at end march, will try and do as many as poss b4 i go to afghan
will try and get on one of the days that the forum lads are on prob cadwell or donnington
kr1s project wanted
I'm booked on at Cadwell with Hottrax in April, if you fancy coming along?
- corky
Its on a monday the 14th IIRC. Would love to see your bike in the flesh.corky wrote:will speak to the lads see if they fancy a bit of camping![]()
what date is it? can only do weekends at the moment
