Well it's Green and a bike !!!
Post by headcoats » Wed Aug 10, 2016 9:04 am
Many Thanks to Boxbridge (Doug)
He helped me out a lot with my questions but looks to have solved the mystery of the left/right piston mix up :P
He suggested that the circlip from the pistons would probably be missing from the "outer" side, so that would determine which bore they came from =D>
Post by headcoats » Sun Oct 30, 2016 8:11 pm
Started stripping the top end down now :shock:
So will be hopefully fitting the 865 barrels , get the shims done and check valve seals etc are working properly, then put it all back together 8-[
Post by Binetta Steve » Sun Oct 30, 2016 8:31 pm
Brilliant just in time for ......winter!
Post by headcoats » Sun Oct 30, 2016 10:13 pm
It will take me all winter the pace I work at :lol:
It will take me weeks to do the shim calculations :oops:
bozbridge
Post by bozbridge » Sun Oct 30, 2016 10:22 pm
As far as I can see the only reason for Winter is to get engines rebuilt :lol: Let us know how you're getting on..
Post by headcoats » Mon Oct 31, 2016 11:47 pm
bozbridge wrote:As far as I can see the only reason for Winter is to get engines rebuilt :lol: Let us know how you're getting on..
Don't worry Doug I may be frantically PM'ing you in the not too distant future :lol:
Post by headcoats » Fri Jan 20, 2017 11:03 pm
I see I posted on 30th Oct to announce I had started stripping the top end :shock:
Today it ran for the first time , well after I had to put some more juice in the battery :oops:
Just let it warm up gently on drive but haven't taken it out yet !
So still early days until I take a ride out, but they have salted the roads around here today #-o
Post by headcoats » Sat Apr 01, 2017 9:31 pm
Been to dyno at last !!!
865 barrels and the Keihin CR 35 smoothbore carbs
Made more Torque at low revs which was a surprise
Didn't alter any jetting as it was close
Post by headcoats » Wed Jan 17, 2018 4:08 pm
Just reinstated as many pics as I could
Post by headcoats » Sat Jan 27, 2018 9:32 pm
Post by Garry » Sun Jan 28, 2018 10:57 am
That engine looks more oil tight than my KR1S 8)
Post by Binetta Steve » Sun Jan 28, 2018 6:02 pm
Theres a dam site more unions and connections on that engine! The carbs look superb. 48 to 59 Is a step up in torque that looks substantial!
Post by headcoats » Sun Jan 28, 2018 6:34 pm
Yes well pleased with the torque :mrgreen:
It really makes you think what they do to these engines at the factory to get such paltry torque and horsepower figures
Must be my DIY tuning of the head with my rat tail files :lol:
Taking rear pegs off too to lighten it a bit more
So have so far
removed front and rear metal mudguards
changed the Chromed rims to alloy rims
removed centre stand
removed standard silencers
Swopped metal side panels for later plastic ones
Removed metal chain guard
Removed rear footrests
Post by headcoats » Fri Feb 16, 2018 11:19 pm
Gained some weight :shock:
Got some bigger more blingy tank badges !
More fakeness :lol:
Post by headcoats » Wed Mar 21, 2018 11:16 am
Got a Fandango oil temperature gauge that sits in the filler cap :P
These engines run hot and in traffic they start cooking so will be interesting what it reaches
In the notes it says 80 degrees is the oil running temperature :?:
