This might take a while!!!
Re: This might take a while!!!
Yep, that's a known mod, match the sub ports to valve and it's clear in the picture now
I don't know, I didn't put it thereLuders wrote:What was that extra bridge for Jan?
probably strenght but aparently it wasn't nescesary.
you've never seen it ? I'll have a look if I still have originals
Yeah I've seen them before, just always wondered what it was for.
ok then, just for those who haven't seen it :
great looking engine there doug =D>
Looked at matching the valve windows up. I can't match the transfer to the valve with the kit I've got but as the valve is bigger and it's a step up for the gas flow so it's not all bad. Then I noticed I can match where the valve meets the exhaust casting, top edge had about a mm step that the gas coming through the valve would hit and the bottom edge was a bit out so at least I think I did a little bit of good..
side I haven't done yet hopefully shows how badly the valve meets the exhaust casting
side I have done, pic isn't great but top and bottom do match the casting now (honest!)
jarno wrote:great looking engine there doug =D>
Cheers lads, it's keeping me busy500bernie wrote:Looking good Doug
Hi Doug
Nice finish (what did you use)?
The original paint/lacquer finish was shot so I took it off with some thinners and really fine scotch bright. Then evened out the alloy surface with emery (some surface of the leg was machined smooth, other areas were still rough cast), took the scratches out with a graded polishing mop then I wanted a brushed finish so more scotch bright (tricky to get an even finish on it). I've used a silicone surface spray and I'm going to see how well it lasts, I'm hoping not to lacquer them again if I can keep them looking right.
There has been no degradation of the polished finish on any of the bits on my bike (hope it stays that way).
I used to use an abrasive impregnated rubber block (called a Loybock) to get a brushed or even a polished finish to quite badly corroded alloy.
I usually finish the surfaces off with a coat of canuba wax, I just wipe the surfaces clean
Handy tips! Thanks for the info, had never heard of a loybock or Canuba wax.. Closest I found on a quick search would be this I think?
http://www.amazon.co.uk/Garryson-Garryf ... B0001P08UQ
The Canuba wax was simple enough to find. Both forks need some more attention but I'm happy with them so far and handy to know I've got a good chance of keeping them right.. wasn't in the budget to pay for them to be redone
