R6 rear shock?
- Christoph
- Newbie
R6 rear shock?
I´ve seen that sometimes R6 rear shocks mounted at the KR1S. Which build years from the R6 want fit? Can someone help me? [-o<
Regards
Christoph
Regards
Christoph
Re: R6 rear shock?
you need one of the "latest models", meaning all the versions that look like the current one. not the old ones (up 'till 2002/3 ?).
I have one from the first years of "the new one".
- Christoph
- Newbie
Re: R6 rear shock?
Jan, thanks for your answer. So I can take every shock from R6 that built after 2003, right? That´s good news. I don´t have to put so much money in a Wilbers shock, I put it to your cylinder head!
Christoph
Christoph
Re: R6 rear shock?
you need to rebuilt your airbox also if you want to place the r6 shock christoph.
Re: R6 rear shock?
Have you considered having your kr1s shock revalved and resprung?saves the hassle of modding the airbox.Also the bike is designed to run on a standard airbox if you reduce it's size this will more than likely end up with carburation adjustment/hassle.
Rich
Rich
Re: R6 rear shock?
The R6 shock is also too long, so you will need longer dog bones
Re: R6 rear shock?
I totaly agree, you just can't stick an R6 shock in and thinck it will be ok.Luders wrote:The R6 shock is also too long, so you will need longer dog bones
- Christoph
- Newbie
Re: R6 rear shock?
Thanks for all your answers! I didn´t know that the airbox need to be changed. I´ve thought about it´s like plug & play .
I´ve got an offer for check & refill, polish the piston rod, guide bush, oil seal & backup ring for 175 €. I think that´s o.k. (and original )
Maybe I put on a progressive spring but this is a little bit expensive. I post some pics when it´s prepared.
Christoph
Christoph
Re: R6 rear shock?
- Christoph
- Newbie
Re: R6 rear shock?
I´ve got it back and here are the pics.
This is original condition
and this is my "new" one
It´s too bad that I can´t test it at once!
Christoph
Christoph
Re: R6 rear shock?
looking very nice christoph.
what kind of spring did you use a WP?
- Christoph
- Newbie
Re: R6 rear shock?
yes it´s a progressive WP spring (to get only in white or orange - special colours against extra charge but it´s expensive enough) and a new stainless reservoir hose. I hope this can compete with my wilbers shock in my green one!
