reg/rec
Re: reg/rec
best is not to run the engine anymore, not even 5 sec, because you can burn the CDI/REV counter very easily.
and yes, you definitly need another one.
Re: reg/rec
Re: reg/rec
thank you both for info, will get a new one ordered
Re: reg/rec
got the reg/rec (RR26) today and its physically a lot bigger than standard one, is it the same reg/rec for both kr1 and 1s, i did look on the parts fiche and i am sure its the same part number for both, any way a bit filing here and there and its fitted and seems ok, its now reading between 14.40 and 14.69 volts with motor running.
20130918_155926 by bob64bob, on Flickr
