question for the racers.
as you know I am building a track bike.
it wont be for races, just the odd track day.
gear oil filler / gear oil drain bolt. [anything else]
as there were other parts
wired before, things like r clips /pad retaining pins/brake caliper to fork
bolts[/img]
That's it Martin. Where R clips are used, lock wire them. I use an R clip through the castle nut on the rear axle for example.
You need to fit a shark fin as well.
