How to remove alternator/cdi flywheels.
StotheH
Post by StotheH »
So I've no doubt called both parts by the wrong name but anyway...
I've got my engine apart and managed to remove the alternator rotor using a home made 3 hole puller and bolts. How do you remove the rotor on the other crank shaft? The center of the rotor just has a thread on it about 30mm across. I tried getting a nut in that size and thread pitch but no dice.
Hopefully someone knows what I'm talking about. Love to know what tool I need or need to make to get this thing off.
98' VFR800Fi
75 KH400
84 KR250
you will need a flywheelpuller with the correct thread. I don't have a KR250 so can't tell you what it is.
dougindoors
Post by dougindoors »
[quote="JanBros"]you will need a flywheelpuller with the correct thread. I don't have a KR250 so can't tell you what it is.[/quote
leave the nut on flush with the end of the shaft, and a sharp blow with a hammer will shock it off the taper
1984 Kawasaki KR250A
2 Smokey and they bandit
StrokerBoy
Post by StrokerBoy »
It's very easy, you just need Kawasaki Special Tools :
Flywheel Holder 57001-308,
Magneto Flywheel Puller 57001-1191,
Rotor Puller 57001-1099,
Rotor Holder 57001-1197 and
Magneto Puller 57001-259.
It's all there on pages 15-24/25 of the workshop manual. :D
And no, I don't own any of those tools I'm afraid. :cry:
Yamaha RD350LC,
Suzuki GSX-R750RK & RB50 Gag.
I use a flywheel puller off eBay for the AR125's - cost me about £10 and used it loads of times. I don't have a KR250A but I wouldn't be surprised if it is the same thread etc. Usually it's a combination of the puller and some taps to work the flywheel and magneto off the crank - taking care not to damage the magnets etc :?
StotheH
Post by StotheH »
I ended up welding a couple of nuts and bolts into a puller. No big deal. None of the local bike shops/mechanics had the right size puller.
98' VFR800Fi
75 KH400
84 KR250
