source for new KR250 Tandem Twin fork tubes ?
pepsi
Post by pepsi »
Where can I get a set of new good quality fork tubes ?
As long as yours are still straight, your probably better off getting them re-chromed, as your going to struggle finding any NOS ones.
pepsi
Post by pepsi »
yea that’s what I figured, its great these little bikes are so rare and exclusive \:D/
(what about cross over parts from maybe a EX250?)
pepsi
Re: source for new KR250 Tandem Twin fork tubes ?
Post by pepsi »
I wonder if these will work? they have the same part number ,44013-1222
http://www.bazar-de-la-becane.fr/tube%2 ... asaki.html
http://www.webike.net/sd/21921894/
pepsi
Post by pepsi »
dougindoors
Post by dougindoors »
there is some on ebay aus prob be cheaper than shipping from the UK
1984 Kawasaki KR250A
2 Smokey and they bandit
pepsi
Post by pepsi »
dougindoors wrote:there is some on ebay aus prob be cheaper than shipping from the UK
do you mean these used ones? They have the same deep pits that mine have. Whats up with that? :shock:
http://www.ebay.com.au/itm/Front-Suspen ... Swd4tUFlSy
StrokerBoy
Post by StrokerBoy »
As ScottaKR said, it'd be better to get yours rechromed. In the UK Philpots are keeping all our old bikes on the road, is there anywhere near you that offers a similar service ?
Yamaha RD350LC,
Suzuki GSX-R750RK & RB50 Gag.
pepsi
Post by pepsi »
StrokerBoy wrote:As ScottaKR said, it'd be better to get yours rechromed. In the UK Philpots are keeping all our old bikes on the road, is there anywhere near you that offers a similar service ?
I do not think rechroming will fill in the pits, wouldn't the new ones in the ebay listing, work?
StrokerBoy
I don't know if they'll fit or not.
You'd be surprised what can be restored. Pits aren't a problem, even slight bending can be rectified.
Yamaha RD350LC,
dougindoors
the rechroming process does not just mean a coat of chrome philpots grind back the tube until its below the pitting then apply chrome back to the original diameter approx. £100 per tube, I need to get a pair of AR125 tubes done, ouch but the only answer.
pepsi
Post by pepsi »
dougindoors wrote: the rechroming process does not just mean a coat of chrome philpots grind back the tube until its below the pitting then apply chrome back to the original diameter approx. £100 per tube, I need to get a pair of AR125 tubes done, ouch but the only answer.
I might look into it, thanks for the info.
I want to get the bike on the road to see if the forks leak, as it seems the pits are above where the seals ride.
heres a close up of the pits on the fork tubes that are listed in Japan, they are like mine.
dougindoors
if the pitting's above the seal running area there's no problem, I read an article in cmm about repairing pitted areas with araldite and smoothing them back, I have tried it and it worked for a while, you really need to clean the rust right out to get it stick proper.
sulli
Post by sulli »
Hi Pepsi thought you might find this interesting
http://www.radhardchroming.com.au/Page/ ... nditioning
Post by Gerrit »
Surely there are companies in the US that offer a similar service?
