hi all
im having a little problem with my kmx (yer yer its not a kr kr1 kr1s but its a smoker)
anyway i brought some plugs from the usa with closed caps but my coil cap only accepts opened caps
so can i buy a replacement spark plug cap that accepts these
im asking cause i dont want them taking the pish in the bike shop
cheers lee
silly question time
silly question time
2 strokes our way of life
- ScottaKR
Yep, if you mean diff sorts for solid terminal/terminal nut fitted or threaded terminal fitting.
Have a shufty here
http://www.spark-plugs.co.uk/pages/pric ... g_caps.htm
That lists as diff sorts, no idea about the company just using as an example
Have a shufty here
cheers mark your a star i mean the cap on top of the sparkplugWhat exactly do you mean by closed or opened caps?
Maybe post a pic of the old plug as a refference.
ive brought 20 br8es from the usa closed cap and was just wondering if i could buy a ngk spark plug cap so i can use these plugs
they work out at about £1.20 each with the post
£3.50 in the uk (rip off britain)
cheers all lee
