New Build Project - KR-1 with 421 Athena Banshee motor.
Re: New Build Project - KR-1 with 421 Athena Banshee motor.
Post by pookie »
Pics are fine, as Sp.Bott says it's nice to have some quality content on this forum, I'm not on social media which seems to be the go to place nowadays and unfortunately I've owned my bog standard Kr-1 for over 36 years now so apart from the odd ride out and polish there's not much content I can provide. :oops:
pictures are back.
RickNC30
Post by RickNC30 »
Final Drive -
I always knew that this would involve some juggling to get the chain run correct as the stock YPVS front and NC30 rear sprockets were around half an inch out of line.
This special front sprocket from an outfit called Fast from the Past in the States deals with most of it - it has an offset of 10mm and I managed to squeeze another 1mm by putting a shim in behind it without losing the engagement of the lock washer on the end of the shaft -
Talon engineering in the UK actually make a similar sprocket but they haven`t been replying to calls or emails for the last four months so I have to assume that they have gone out of business which left me the choice of buying one from a European supplier for about £80 or an American one for half that price.
I have regained another 2mm of the offset with some subtle machining of a Talon 520 rear (luckily Dennis Trollope had one on the shelf) -
I don`t think that the gold sprocket really suits this build but I`m stuck with the compromises of limited choice -
This is a workable solution but something I may have to revisit later. I have fitted a heavy duty non O-ring race chain with a clip link for now as I will need to check the chain clearance when we re-route that left side exhaust tail pipe.
Stock gearing on a 350 YPVS is 17/39 but that`s a bike which makes 60 bhp, weighs 145kg and has an 18" rear wheel - this bike will potentially make 80bhp, weigh 120kg and has a 17" wheel, each of those factors would warrant higher gearing in it`s own right so all three together certainly will.
I have no choice with the front sprocket which is only available in 17t from any source - 38t is the smallest `off the peg` NC30 rear so that`s what I`m going with for now but I fully expect to be needing a smaller, custom made rear further down the line.
Putting the chain and sprockets on has enabled me properly to test the gear selection with the Chinese `uprated` cam and detent arm and I have to report that it is so bad that I am going to strip the right side of the motor and put the stock parts back in - yes the location in each gear is positive, so positive that the force required to shift is nearly enough to bend the gear lever, also the neutral detent position is so tenuous that it takes half a dozen attempts to find it and as soon as you turn the rear wheel of touch the kickstart it drops straight back into first.
We live and learn...
RickNC30
Post by RickNC30 »
Finally some more progress to report - I collected the bike today after having the exhaust custom fitted around the modified chassis parts.
My friend Chris is that rare thing, a proper old school bike engineer with great machining and fabrication skills who will turn his hand to any job a special builder might need and do it well - here are the results of his work -
Extra bend in the left stinger pipe to clear the single side swingarm -
Stand mods and extended mounting bracket so nothing touches when the stand is up -
-and an elegant bit of bracketry to fix the chambers together under the engine and mount them to the underside of the frame -
The brackets are staggered so each chamber is individually rubber mounted and the tubular nut on the bottom will double as the mounting point for the fairing belly pan.
Overall a very tidy job - the whole exhaust is well tucked away and completely stable...
Post by pookie »
Welcome back! good to see you're not rushing this project :lol: I like the way the downpipes cross over each other like the Yamaha tdr 250, shame that they will be hidden when the bellypan goes on, keep up the good work.
I don't like the way the springs that keep the exhusts on the cylinders are touching the pipes and make an angle .
I think they'll make noise and wear quickly at the touching point.
everything else is top.
