Dog bones for shock swap
Wheels, shocks, forks, frame
Gonzo355
Post by Gonzo355 » Thu Aug 22, 2019 8:33 am
Hi does any know the length of dog bones to achieve standard ride height using an r6 shock or what would fit.
Many thanks
Martin
Re: Dog bones for shock swap
Post by KR-1R » Sun Oct 20, 2019 6:30 am
if memory correct standard shock about 273mm and R6 raven somewhere about 290.
Using the standard KR links, the ride height is +40mm over standard,
so probably about 15mm longer links than standard (Not just from difference in shock lengths) will bring ride height back down
10mm longer links will give you bit more ride height modern look etc
you could look at weld and fill the eye holes and then redrill each 5mm further apart giving 10mm
BDK make shorter ALLOY ones for £160 pounds but that will raise a standard bike
i have seen adjustable links with threaded middles too
have a look here for R6 conversion
viewtopic.php?f=1&t=46632&p=135779
Post by KR-1R » Wed Nov 06, 2019 10:54 pm
the -1085 KR-1 links are the same as found on the ZXR250(A)/(B) 39111-1085, 39111-1108
I think the -1115 ZXR250(C) links are longer... approx 127mm eye, with ~20mm offset
Post by Gerrit » Thu Nov 07, 2019 10:47 am
The standard dogbones are marked 1085 and measure 108.5 mm centre to centre. The 1115 dogbones will probably be 111.5 mm centre to centre i.e. 3 mm longer than standard. There may be more suitable longer dogbones from a different Kawasaki model, but it may take quite a bit of research to discover which one.
Post by KR-1R » Thu Nov 07, 2019 11:48 am
little bit of parallax going on in photo/camera position... but >125mm <130mm
KHI not a model for consistency... why are there two model years for 1991? unless ZXR250/ZXR250R
