Nikon pipes
Robypvs
Nikon pipes
Post by Robypvs »
Hi
Can anyone advise what main jets I should use for a set of Nikon pipes for my Kr1s.
Thank you
Re: Nikon pipes
did Kevin Underhill used to run nikon`s ?
Re: Nikon pipes
Re: Nikon pipes
Yes, Kevin I think did have nikons but he had 35mm carbs as well.
Re: Nikon pipes
You wouldn't need to change your jetting on a stock bike just changing the exhausts. If anything, they are not as good as standard pipes from a performance perspective.
Robypvs
Re: Nikon pipes
Post by Robypvs »
Thank you for the info will try them and check what it is running after a plug chop.
Re: Nikon pipes
Photos or even better a video, would be good 8)
