Oil blowing from left pipe
Robypvs
Post by Robypvs » Sat Aug 13, 2016 6:35 pm
Hi
Have just built a Kr from boxes and on start up it seams to be blowing oil out of the left hand pipe which looks like gear box oil .
Am I right The crank oil seals have gone or could I have over filled the gear box oil ?
If it is the crank oil seals which one or would I have to do a full crank rebuild ?
Regards
Rob
Re: Oil blowing from left pipe
Post by Binetta Steve » Sat Aug 13, 2016 9:03 pm
Do you have a window on your gearbox side case? .If its overfull you can drop out small amonts via the drain plug on the LHS
Robypvs
Post by Robypvs » Sun Aug 14, 2016 8:39 am
Thank you for reply but was making sure it's the crank oil seal before I pull it apart as cannot work out if oil is topped up to much why it could go into the left barrel .
Gerrit
Post by Gerrit » Fri Aug 19, 2016 3:28 pm
If it's a crank seal then it's the LH inner seal. The oil can be sucked in from the balancer drive gear cavity- when the engine is running there will be an oil mist there. Chances are the centre shaft is worn, asuming the crank hasn't been rebuilt and fitted with a proper centre shaft.
Robypvs
Post by Robypvs » Sat Aug 20, 2016 12:49 pm
Hi
Thank you for that will start pulling it apart.
Regards
Rob
Users browsing this forum: No registered users and 5 guests
