kr1s running wiseco prolight piston
slashing
Post by slashing » Mon May 09, 2016 3:24 pm
Does any one know if you need to change carb set up when running wiseco pro light yz 125 pistons all the rest of the bike is in std condtion
Re: kr1s running wiseco prolight piston
Post by jarno » Mon May 09, 2016 9:09 pm
I have got a bike with those pistons (cilinders shortened of at the bottom to fit these pistons)
He runs at standard carb setup Rob,the only divergence is that these pistons are single ring.
Cheers jarno,
slashing
Post by slashing » Mon May 09, 2016 9:21 pm
Thanks Jarno its the set off the kr1s your friend owned, i am going to put them on another bike as i put the other one back to twin ring wossners pistons an fresh replated barrels thanks for reply.
Post by JanBros » Mon May 09, 2016 10:18 pm
I use them, but my engine is far from standard
