New or replacemnt Throttle cable
waza1972
Post by waza1972 »
Anyone know where I can get a new or good 2nd hand
Throttle cable from. The revs on mine keep hanging and when
I move the cable it either drops to tick over or revs uncontrolably.
I have checked all the routing and its fine and the slides arent sticking either.
Any help would be appreciated.
Cheers Waza.
mellorp
Re: New or replacemnt Throttle cable
Post by mellorp »
venhill will make you a cable http://www.venhill.co.uk/
You have an air leak. Either the carb rubbers are perished or the they aren't sealing properly. Get some gas leak fluid and see if it bubbles. Cheapskates will try and use washing up liquid.
http://www.screwfix.com/p/gas-leak-dete ... oCpCDw_wcB
waza1972
Post by waza1972 »
Cheers mate, its got brand new rubbers on. When i move the throttle cable it makes a big difference. I have checked everything i could think of so hopefully the cable is the issue.
mellorp
Post by mellorp »
I'd still do an air leak test
Have you checked the cable adjusters on top of the carbs are set right
Best way is to slacken them off and remove the airbox
Also back out the idle screws on the sides of the side of the carbs
Then put a finger down each carb to touch the slides
Turn each adjuster until you just start to feel the slide go taught/start to lift
You want them set just slightly before they reach this stage
Then turn in each idle screw until you can feel it start to make contact/lift each slide
When you start the bike you will find you then need to turn in each idle screw an equal amount to get
a tickover and then just fine adjust
Off course you may have done all this but if not i would try the above before buying a new cable
waza1972
Post by waza1972 »
cheers mate, i have set the idle screws and checked the cable adjustment it ticks over fine. Then you go up the road and back and the revs hang at about 2k. If you drop into 1st they will then go back to tick over. If you move the cable about the revs will either drop or rev really high hence i thought it might be a cable issue.
