two stroke oil pump
waza1972
two stroke oil pump
Post by waza1972 »
KR1 "89" Ello all, is there a way to bleed the the pump
and how do I know its setup correctly?
Re: two stroke oil pump
Bleed screw is located on the top of the oil pump.
I stuck a bit of premix in a temp tank and ran the bike on tickover until the oil ran free from the pump bleed screw, tightened it up and held the pump on full until the air bubbles disappeared from the oil lines.
Make sure when you synchronise your carbs, that you check the oil pump mark lines up when you are finished.
waza1972
Post by waza1972 »
Cheers Bernie, will check this the weekend.
Im going to try and get hold of a Haynes
Manual or same as to help me out a bit. Cheers, Waza.
No need for a Haynes manual go up to the board index top left on this page. Then krkive , wow what a resource.
This link may also get you there , steve
viewtopic.php?f=22&t=817
waza1972
Post by waza1972 »
Xlent, will do. Cheers.
