Fairing Well nuts,
Plastic bits and Paint
Fairing Well nuts,
Not had any luck doing a search,
Original ones are.
Well nut £3.79
Washer £1.69
Screw £1.79 All plus vat, :shock:
Anyone had any off ebay, if so would you have a link and are they 5mm.
I need six of them.
Ive used these and seem ok
Ebay item 130631834700
£4.99 for set 6
14mm long seemed a perfect fit on my bellypan
Of course if you don't need the ss bolts then you can pick up a set cheaper.
They'll be OK.
Or there's these.......
http://www.ebay.co.uk/itm/260828876390? ... 1439.l2649
I was quoted a £1 a screw for OEM screws.
I want to keep the original fittings, and after a scrat round the garage today I found 15 good screws \:D/ and use the well nuts from ebay.
Cheers chaps have ordered some, :D
Good item, much cheaper and good fit.
Cheers for that. :)
Brian Waters
Post by Brian Waters »
Thanks for link chaps, still works just the job .
