Gremlins back..
corky
Gremlins back..
Post by corky »
thought it was gone..but its back,
Put my new hoses on today, changed coolant,warmed bike up,checked for leaks ...all ok.
put my gear on, locked house up, get on bike, great...
4 miles into ride, time to thrash it...
1st,2nd,3rd,4th..flying.....then dead, no revs pull in clutch.. engine revs
feed clutch out engine dies....bugger 4 miles from home...
think,think, long way to push...
yippee...disconnected clutch switch at lever and road home
when this happened last year i removed my side stand switch and bridged connecter and it was fine,
checked connector, fine, resistance there, checked all visible stuff all ok..
any ideas before i change my CDI am i missing anything?
kr1s project wanted
aprillia rs125 track bike
03 r6 race/trackbike
dr500 flat tracker project
always have mine disconnected at the lever
hasn't this cured the problem? if it has would leave it that way and carry
on :)
corky
Post by corky »
the problem is that it would always be playing on my mind,...the sidestand switches are renowned for topping up with water and playing up so i was happy to bypass it,
but by disconnecting the clutch switch i will just be ignoring the problem not fxing it or really knowing what it is....
am i weird?
kr1s project wanted
i know where you're coming from
never understood the thing myself - all i know is that it works and
its free :)
It's only there to stop the brain dead from starting the bike up in gear and then watching it fly down the road without them. I would just bypass it. Its most likely a lose conection.
