5000 revs
5000 revs
Ok so in goes my freshly rebuilt (well, top anyway) engine into my never engine project bike, go out for a ride- and on the road won't rev past 5/ 5and a half thousand. Doubt the bike is producing more than 10-15 brake max as it is. Just spent 400 notes on the engine so should be no troubles there, carbs are clean- so elecs? After the ride I put down the side stand and engine cuts out, even though my hand is off the clutch.
I remember someone saying something about this topic on the old forum- but obviously can't find that now so any ideas!?
Cheers!!
Cheers!!
post
mine always cuts out when u put s/stand down, its supposed too i believe, although i can start it if its plenty of fuel in with s/stand down..ted
remember, you can strap a monkey to a rocket, but that won,t make it a pilot..
that sounds like it could be the diode under the tank. Grap your self a copy of the manual and a multimeter and best of luck. Finding the fault on mine was a sod as it was only failing under load for the first month or so until it packed in totally. Once that happened it was easy to find what was causing itkr1chris wrote: rev needle bounces about when side stand goes down but not while moving. Lets wiat and see...
Yes, I know, this is a cop out.... but.
I spent a couple more eves tinkering with it (yes the bike), with no luck- also a lot of my spares cannot really be described as 'known good' rather than 'likely shit'- which is why they are collecting dust and/or small animals in search of a new home.
So, I took the bike to a dyno, and pulled out the credit card.
Problem was- combination of dodgy wiring around base of engine and flywheel, and previous owner's (in loosest sense of the word) maverick jetting.
Journey home was substancially more fun than journey there....
Totally std bike (kr1), not yet run in properly- 45.3 bhp. Does this sound ok, i.e as opposed to pub figures this is actually the exact figure- or anything else that might help? Power questions, definitely more fun than wiring questions! Still stutters abit around 5/ 6 but has never been on a run as it is so hoping this might improve , optomistic maybe but fingers crossed...!
