Switchgear tab fix
smoovly
Switchgear tab fix
Post by smoovly » Tue Mar 15, 2016 10:12 pm
I worked out a way to fix the missing tab on the back of the switchgear housings. A small piece of plastic tubing from a radio control plane linkage and a small self-tapping screw does the job nicely and fits better and tighter than the factory method.
I've got some spare bits, enough for about 8 switches (you need to find the screws) but if you want some PM me and I will post what you need.
smoovly
Re: Switchgear tab fix
Post by smoovly » Tue Mar 15, 2016 10:15 pm
No idea why the image is upside down...
James P
Post by James P » Sat Mar 19, 2016 12:22 pm
Good idea. Even just the screw by itself (without the plastic tube) may be enough.
smoovly wrote:No idea why the image is upside down...
You're not in Australia too, are you? :lol:
smoovly
Post by smoovly » Sun Mar 20, 2016 1:47 pm
No, London but visiting Sydney for work next month.
The screw is no good on its own, wobbles too much. With the plastic sleeve it's better than original.
If you want me to bring some over let me know.
