Losing spark
Fastasphunk
Losing spark
Post by Fastasphunk » Wed Apr 01, 2020 9:16 pm
hi all, right hoping someone can help me, kr1s starts no problem runs for a short while then cuts out pulled plug out and there's no spark!! Leave it for a couple of hours switch on first kick she fires and then does the same!!!! Fully charged battery
Thanks in advance jason
Re: Losing spark
Post by JanBros » Thu Apr 02, 2020 1:45 pm
battery isn't needed for the ignition, a KR will start without a battery (IF you switch off the lights)
most likely your stator is faulty. there are 2 coils different to the others in it who are solely for the ignition and they are known to fail too often.
Fastasphunk
Re: Losing spark
Post by Fastasphunk » Thu Apr 02, 2020 4:15 pm
OK thanks for that, its had a new stator all be it a while ago but done very little miles since fitted, you still think it could be that? I'm happy to buy one or buy anything that will solve the problem cheers Jason
Coose
Re: Losing spark
Post by Coose » Thu Apr 02, 2020 6:05 pm
Electrex World sell a replacement stator, but it's easy enough to check yours.
Re: Losing spark
Post by 500bernie » Thu Apr 02, 2020 7:14 pm
Have you got a known good coil to swap the existing one with?
Re: Losing spark
Post by JanBros » Fri Apr 03, 2020 1:20 pm
no , it's not when like in this case in works sometimes.
only thing you can try is measure the output voltage of the 2 coils when it is working and again immediatly after the ignition stops working. can't tell the wire colors as I'm not at home.
Re: Losing spark
Post by JanBros » Sat Apr 04, 2020 3:27 pm
page 15-17 in the KR1 manual :
W-R : 2-7 ohm
B-R : 100-200 ohm
infinite between any of the 3 wires and ground.
but I would be more interested in the voltage output of the wires, as when the engine is turning over, there are vibrations everywhere which can cause a difference (causes wires to "move" and touch where the isolation is rubbed off).
Coose
Re: Losing spark
Post by Coose » Sat Apr 04, 2020 11:59 pm
It's the first thing to check, being free. If it's verging on being out of tolerance (as stated the resistance values above) it's worth replacing the stator.
Mine failed last year without warning, so yours might be telling you something...
