Check your Brake Arm Fixing Bolts
Braking issues
symtec23
Post by symtec23 »
Just a reminder to all, to check the bolt that holds the rear caliper to the braking arm that runs on the underside of the swingarm, CHECK IT. I know that this might seem stupid but I have had a KR1 for a month now and the other day,while braking hard into a tight right hander, the bolt snapped. The caliper rotated to the top of the swingarm, snapping of the bleed nipple, bent the disk( i dont know how but it did)and at the same time ripped the brake line in half. Nearly got highsided big time. Luckily I was only 2 kays from home so I limped the bike home for urgent repairs and a change of underwear. Ive never heard of this before, but Im letting you know, in the hope that it doesn't happen to you guys.
vector74
Post by vector74 »
Sounds like what happened mine. It had a broken off bleed nipple on rear caliper and I was wondering how it happened :)
kr1-s c2
i reckon use stainless steel bolts with locknut
nate
Post by nate »
martin wrote:i reckon use stainless steel bolts with locknut
But make sure they are high tensile :mrgreen:
Sounds bad :shock:
I'm fitting the KR1S front and rear to my LC
Is this a known problem and is there a stronger bolt to fit ?
headcoats wrote:Sounds bad :shock:
A decent high tensile stainless bolt will be fine. Its a known problem is as far as any bolt can, after years of use, break. Its just one of those things worth keeping an eye on and/or replacing when you next strip something in that area of the bike.
another way round the problem is not to use the back brake :)
Garry wrote:another way round the problem is not to use the back brake :)
:lol: :lol: :lol:
I only ever use it in the paddock or for stoping on the start finish line at the start of a race. Have had to use it once or twice when I've over cooked a corner but that's about it.
Red Devil 777
Post by Red Devil 777 »
:lol: :lol: :lol:
What's a back brake?
mr_bungholeo
Post by mr_bungholeo »
Red Devil 777 wrote:
:lol: :lol: :lol:
what's a brake..???
danny harris.....R.I.P
only thing with not using it , is when it comes to the MOT, and the
mechanic presses his size 12 down with all his might and it binds for
the trip home #-o
