i've just got hold of a set of zxr 400 h forks and yolks,apart from a mudguard,what else do i need,will the kr bars fit into the 400 clipons ?,i want to use my kr's wheel and disc's with the bandit 1250 calipers i have......
can i use the kr's spindle or do i have to find a h spindle too ?
i suppose i'll find out when the forks arrive,but it would be nice to find out before hand
cheers
doug
zxr 400 forks,what exactly do i need ?
KR1 or KR1S wheel ?
you'll need a 5mm spacer for the stem.
axle : original is too short, and the ZXR's is too big. best thing to do is turn the ZXR's down.
wheel : you'll need spacers and you'll need to align the discs since the KR's wheels are smaller.
brakes : if you have an S-wheel, you can use your discs, if you have a KR1, you'll need 300mm discs, but I don't thinck you'll find 300mm discs that fit a KR1 wheel.
- smithyrc30
wheel spindle
I would go the other way....
Get the 'other size' bearings with the 20mm bore and matching seals. If you take the old ones to a bearing suppliers, I'd be very surprised if they didn't have the parts 'on the shelf'.
The bearings them selves will be about a fiver each, and the seals about three. Just make a new spacer to go between the bearings with a 20mm bore instead of the 17mm one.
Machining down a 20mm hardened spindle and cutting a new thread onto it seems to be a recipe for problems to me.
The standard bearing is a 6303-2RS I think, which is 47mm o.d. with a 17mm bore and 14mm width.
The alternative is a 6204-2RS which is 20mm bore with the same diameter o.d. and the same width.
This place do them and the seals:
http://simplybearings.co.uk/shop/advanc ... 14&x=0&y=0
As do this place:
http://www.bearingshopuk.co.uk/6204-2rs-2688-p.asp
Similar prices.
Added to that you know your wheel bearings are in good shape, something that might not be the case with those already in.
As do this place:
Similar prices.
are you sure about the o/d for the kr1s wheel ?
ade.
have had no problems as yet with turning the spindle down( two years several track days many hard landings over the mountain ) cost was if i remember about £40 to get it done guy said there was enough meat on it i gave him the option of making a complete new one ( they do lots of stuff for nissan and nsk i think.
ade.
ade.
ade.
on the pipe!!!
