RGV front wheel.....?
canolman
Post by canolman »
Does anybody know if the RGV VJ21/22 front wheel will fit into the KR1-S forks that are fitted to my VJ21 Supermono, the forks are marked K313B-R. If so what brake options have I got?
thanks
col
Post by col »
dont think you'll get an rgv wheel in,seem to remember rgv has diferent spindle dia and the calipers wont line up. easier to just get an rgv front end.
are you forks kr1 or kr-1s? easiest way to tell is look at you calipers.
kr1 = two piston calipers
kr-1s four pistons.
canolman
Post by canolman »
#-o ZXR400 calipers!!
col
Post by col »
early zxr calipers will fit on kr-1s forks,not sure of the models, i think the zxr had smaller pads so you may lose some braking preformance but dont quote me on that.
zxr calipers are a touch lighter but i think only a little.
Post by scooble »
the early ZXR400 H model has the same discs and calipers as the KR1S, however, later models starting from the L (I think) have larger 310mm discs and smaller calipers/pads.
