Fitting an RGV 17" wheel into a KR1S
Posted: Fri Apr 24, 2015 5:16 pm
As I have now completed this conversion I thought I'd add the details
An RGV wheel, disk, sprocket carrier, rubbers and a 41/42 tooth sprocket
You need a set of spacers. Boggy on here made mine, good job that man
The 5 piece spacers are designed 1 inside the seal on the sprocket carrier, 1 inside the sprocket carrier, 1 between the bearings in the wheel, 1 in the seal on the disk side of the wheel and 1 between the swing arm and the calliper mounting bracket.
You need 4 disk bolts from Kawasaki (well I did) as the collar of the Suzuki bolts are too wide, and the head of the bolts just catch the calliper bracket.
The bearings on the RGV wheel need replacing as the spindle is different (20mm/17mm). C3, 6303 or 63032RS. Inside Diameter: 17mm Outside Diameter: 47mm Width: 14mm
You will also need the seals and go down from a 20mm ID to 17mm ID
from simply bearings
I had the wheel powder coated as it was a bit tatty, leaving bolts in any of the threads, and to finish off and complement the front tyre a BT090 in 150/60 section
I use a wheel lift
Lining up the wheel spindle and spacers is an absolute doddle, the last spacer I needed to ease the swing arm away from the calliper bracket and it just dropped into place.
Last off you might need to space the chain guard across away from the tyre as the tyre is a very tight fit, a simple washer inside the guard on the locating lug does the trick
Happy Days
And it looks like this, last pic is a close up of the 2 spacers either side of the calliper carrier
I use a wheel lift
Happy Days
